Engine/Transmission (1998.5 - 2002) What Injectors?
Engine/Transmission (1998.5 - 2002) Clutch cylinder install question
Engine/Transmission (1998.5 - 2002) Dse
What injectors would work best? I have an edge ez and tow heavy when towing. Tow 8000# to 13000#. I have been thinking rv 275s, but would stage 1 performance injectors work better without raising egts to high? Where would be the best place to buy these injectors? This is all I want for power. This truck has to last me many years. The ez works well, but from what I've read new injectors with the ez would add the right amount of preformance for me. I like offroading more than street racing. All info welcome. Thanks, Bunyan
Do you already have RV275's?
Foumula mach 1. 6's seem to be the best all around towing injector.
I have Jammer 3's and they drive much better than the DDII's I had before.
If you need to make your truck last a long time I would suggest keeping your upgrades mild. 275s are nice for a little extra power without going to crazy.
If I went with the 1. 6s instead of the rv 275s, what can I expect my egts to be? I do tow heavy, 8000#-13000#s when towing.
That is exactly the same jump I made. While you will have to watch the pyro a little closer when towing grades, I never looked back after the upgrade. A couple months ago I did upgrade my turbo to a PDR HX35/14 but not from necessity. The stock turbo worked fine. I tow about 17-18k combined.
Sixpack are you using a fueling or timing box with your setup. When towing what egts are you seeing?
