I redid my fuel system, I put in a pusher 7# and a prefilter 30 micron. that made my PSI too much so I put in a regulator after the stock pump and routed the relief back to the prefilter so now even the pusher has a small head pressure.....
So now I see 13-14 psi idle, 12, cruise, and no less than 10 WOT because of the better flow. I can adjust these PSI #'s with a turn of a nut either up or down. I might have to get it up a pound since the weater warmed up, it has gone from 14 or so to 13 at idle.
I have 2 boxes making 331 HP at the wheels and 30 PSI boost and still the FP is no less than 10 PSI... .
I believe I have a very reliable system since none of the pumps are working hard.
I also just put in a 18 gal aux tank as you might have seen and the 7# and bleedoff from the regulator helps serve to siphon the fuel from the aux tank to the main as I use it... .
Search "my fuel sytem setup finally done" to see a diagram of my setup.
