Details here: TDR Privileges
What tools are needed to change the rear mail seal? I guess the better questions to ask is, how do you get the seal out of there? I'm going to change it while I have the trannsmision out of the truck. Thanks
Thanks jw... We weren't sure if we could pull the seal without pulling the housing. . (using the screw/bolt and slide hammer method) I'm guess there is no where sleave on the crank??
I've changed 4 of them without removing the "trans adapter". Just drill a small hole in the seal, screw in a screw and pull it out with vice grips, slide hammer, etc. Tap in new seal on dry crank, no probs.
We had the same idea about drilling into the seal and then pulling it out. Sounds like the easiest way to me. I just don't want it to start leaking after I get the clutch in. Thanks
It's not a problem. Just be sure the crank is dry, smooth, and clean. If it's grooved I would set the new seal at a slightly diffrent depth than the old one. Wouldn't hurt to smear a really thin layer of your favorite silicone/permatex around the seal before you tap it in, this will ensure no leaks from the perimiter.
Wear sleave... (nice spelling I have... ) On JD engine we use a wear sleeve on the crank, so the seal does not ride on the crank... When replacing the seal, it comes with a new wear sleeve and seal. . they are installed together all at one time... If there is no wear sleeve nothing to worry about. . they can just be a pain to get off some times... We'll try the easy way first... only pull the plate if we have too...
They make a special seal and wear sleave for them if your crank is groved. If your crank already has the wear sleave you will need the seal made for it, and the special installer to go with it, or you can just change the seal if the wear sleave is still in good shape. I just did mine at 260,000 and the crank looked good. Jake
the way i do it is use a self taper screw use two of them across from each other and use prybars or vise grips like menchond above and pull it strait out if there is a wear sleave just use a small -small chisel and tap lightly betwien the crank and sleave and it will break easily no prob. if it dosnt have one i would put one in insted of groving your crank
As far as I know they have never put the wear sleave and matching seal on from the factory on the B series. All the C's come with them on the rear and the newer ones now have them on the front. I've only done one B that needed the wear sleave on the front, and have never done one on the rear. Every C I've ever taken apart needed the wear sleave on the front. Back in about 1992 I couldn't get the sleave type seal for a C and put on the regular seal and a speedysleave. It cut the speedysleave in half in 500 hours. The wear sleaves are much thicker and made of some good hard material.
I have never pulled the rear seal plate to replace the seal on a B. I just drill the old seal and use a slide hammer, as reccomended in the Cummins manual. Just make sure to drill out a ways so you don't knick the crank. If you do you'll need the wear sleave. When I did mine a few weeks ago I had to drill it in 8 differant spots, as it was really stuck and the slide hammer kept stripping the holes out. Jake
