for the 180 hp--gauges, please up front!
1. TST #8 power kit
2. automatic transmission work--now is the time to pick your stall for the converter to match future power upgrades, and get more line pressure with shift kit or exchange valve body. These are minimum and fine for up to 300 or so hp. If you are going wild, get a completely done transmission from one of the good vendors.
3. #5 power kit and possibly 215 hp or 370 hp injectors. 16 cm2 turbine housing, low restriction muffler and check catalytic converter for partial plugging (backpressure reading at elbow will do this when under power).
4. more timing, about 15. 5 to 16. 5 degrees. ATS exhaust manifold, HX40 turbo precision balanced preferably. 4" exhaust.
5. more air, more fuel, more, more. . . $$$$
