I promise my truck will be strapped to a dyno when marco makes the trip to the states.
Our intentions are not to forget about the vp 44 trucks.
We are limited to what the vp44 can put out for hp gains.
I promise this we be addressed.
Thanks Bob - good to hear - when IS Marco heading our way?
And it seems that while there's a fair number of scattered issues with some users, the more common one I've seen revolves around the smoke issues, especially from a stop. I realize (I think!) that the original Smarty program was developed for fueling increases for stock engines - which was fine for those at that point in mods - but then, like the guys with 3rd generation trucks, as other fueling enhancements such as larger injectors are also added, the combined increase results NOT in more power, just more smoke!
Therefore, reprogramming that provides the same excellent low-RPM performance Smarty is known for, but also alters the fueling to lower more efficient levels should be a plus. I certainly do NOT think the low end performance would be significantly reduced by better control of low end fuel/smoke.
As it stands in my own case with 1. 6 injectors, use ANY level Smarty programs makes around town driving way too high in smoke, even with the Comp switched completely off!
Fact is, the VP-44 has proved to provide FAR more fuel/power than the Smarty calls for - so the primary "need" seems to be better application of that Smarty fueling when combined with the more common aftermarket stuff so they complement, rather than interfere or degrade each other and limit what should be total combined maximum power - just as was done on supplemental Smarty program upgrades MADS provided for the 3rd generation trucks.
At least that's the way *I* see it...
And certainly, NO offense intended against you Bob, or Marco - just venting a bit of what appears to be not too uncommon frustrations, questions and concerns - as well as responding to other poster comments in this thread.
You and Marco may not fully appreciate what you have read here, but I'm sure you have a far better understanding of some of our feelings than you would if we had just kept them to ourselves - the end result SHOULD be an even better end product from Marco and MADS Electronics, and that ultimately benefits us all!
