What is this???
Airbag lite A4 31
U-Connect dead?
I was trying to read my hour meter, but accidentaly help the trip buttun down then turned the ignition on. The whole cluster light up, the tach and speedometer started bouncing around. At the end it flashed C Code then a bunch of numbers and some letters followed. It looked like it was doing a sytem check, but of what? I couldn't find anything in the service manual. Before you ask, NO it wasnt the normal check engine light codes... .
That is how you do a function & light bulb test on the instrument cluster. Those "C" codes are for the cluster, too.
Bob
Yes as stated you triggered the Instrument Cluster Diagnostics. The display shows a two digit code and a two number count. This is a list of Instrument Cluster codes that I have. I think this was from a 2003 manual so there might be new ones.
Instrument Cluster Diagnostic Trouble Codes
01 Airbag warning indicator output circuit shorted
02 Airbag warning indicator output circuit open
03 ABS indicator output circuit shorted
04 ABS indicator output circuit open
05 MIL indicator output circuit shorted
06 MIL indicator output circuit open
07 Wait to start indicator output circuit shorted
08 Wait to start indicator output circuit open
0B BTSI output circuit shorted or open
0C PRNDL switch input circuit shorted
0D PRNDL switch input circuit open
20 Panel dimmer input circuit shorted
21 Panel dimmer input circuit open
22 Headlamp switch input circuit shorted
23 Headlamp switch input circuit open
24 Turn hazard switch input circuit shorted
25 Turn hazard switch input circuit open
26 Panel illumination output circuit shorted or open
27 Courtesy/dome lamp output circuit shorted or open
28 Glovebox/map lamp output circuit shorted or open
29 Cargo lamp output circuit shorted or open
40 Wiper switch input circuit shorted
41 Wiper switch input circuit open
42 Wash/beam input circuit open
60 Passenger door lock switch input circuit shorted
61 Passenger door lock switch input circuit open or short to voltage
62 Passenger door lock switch input circuit stuck
63 Driver door lock switch input circuit shorted
64 Driver door lock switch input circuit open or short to voltage
65 Driver door lock switch input circuit stuck
66 All door lock output circuit shorted to ground or voltage
67 All door unlock output circuit shorted to ground or voltage
68 Driver door unlock output circuit shorted to ground or voltage
69 Passenger cylinder lock switch input circuit shorted
6B Passenger cylinder lock switch input circuit stuck
6C Driver cylinder lock switch input circuit shorted
6E Driver cylinder lock switch input circuit stuck
80 Incorrect odometer value found
81 Remote radio switch circuit high
82 Remote radio switch circuit stuck
A0 Internal module FLASH memory checksum failure
A1 Internal module bootloader failure
A3 BATTERY voltage open
A4 Ignition RUN/START circuit rationality check
A5 TCCM messges not received
A6 Ignition UNLOCK circuit rationality check
A7 VIN checksum error
A8 VIN previously stored
A9 PCI Bus internal failure
AA PCM messages not received
AB TCM messages not received
AC ABS messages not received
AD FCM messages not received
AE ACM messages not received
AF SKIM messages not received
B0 RKE fob battery low
B1 RKE module communication link
B2 Cluster mismatch
00 DONE
67 - All door unlock output circuit shorted to
ground or voltage.
A5 - TCCM messages not received.
A7 - VIN checksum error.
Ad - FCM messages not received.
Do I need to worry about these??
I just ignore them unless there is really something that is evident and related to the code. On mine I have seen codes like some of the above that were just there. Never had any indication that there was really a problem. I think mine were just glitches.
Let's put it like this; make out like you did not accidently find the Instrument Cluster diagnostic sequence. Would you be worried about something wrong with no indication of a problem?
