I think he is asking CI or CJ
That is greatly debated. Some report the CJ will destroy your pre 07 engine, while others report CJ will result in 30% LESS engine wear.
Although it's true the CJ has less detergents and lower TBN keep in mind that we will now use ULSD so less detergent is kinda not important. TBN is lower, however CJ remains within the desirable TBN range over a longer period, unlike CI. I doubt CJ will result in more frequent oil changes. I's not going to be used with high sulfer fuel. Unless you buy off road/farm fuel.
CI will become more and more difficult to locate. I do know Delo will continue with the gallon jugs of CI... . for some time. Shell Rotella CI is available in 55 gallon drums.
It's reported that you can mix CI and CJ in the older engines, like Tugboatphil does. In the long run, it most likely don't matter. Just put oil in that thing. Change it about every 8,000 or more. I change the buses at 10 to 16 on Rotalla "T" CI-4
