What Pressure snubber do i need?
EZ or Quadzilla or Van Aaken?????
Raced an 02 Ford dually
I have an electric Fuel pressure gauge and am in need of a Snubber... . I know some of you out there are using a snubber, and i have look at a couple different site and i notice they all have a couple different snubbers.....
So which one do i need..... and also would a air pressure snubber keep my boost gauge needle steady so i can read it when its going up and down? If so which snubber would i need for that also?
You can make one by plugging the end of the correct size fitting ( Braze the hole closed on brass or JB Weld ) Then drill a . 012 hole through it. I use a magnahelic gauge to check crank case pressures on 2 stroke motors, and this is how I smoothed out the pulses.
