The max the sensor will read is actually 30,000 or register 5 volts. There is a ECU thing to only see 26. 4K max.
Thats what mine is about 6K
the reason I'm asking is, mine has a miss at idle after it is warmed up.
It had this when I bought the truck (used) I thought it was the injectors
so I had Don rebuild them. (F1) Well it still has a miss at idle when warmed up.
I retorqued the connector tubes and no difference.
Wondering where to go from here?
Also read on here someone else has the same exact issues as mine and he had no connector tubes installed and it didn't fix the issue either.
Dennis
Yes, you are most likely correct, my point was, just because you are only reading "26. 4k", does not mean your rp is not higher.
Cheers, Jess
Bob
The warmer the engine gets the worse the idle quality.
When it is cold it idles perfect when it warms up it can even get a shake
if valves were out of adjustment would it make act like this, as far as if it is warmer up or not.
Yes it is still the Oem fca with 182000 miles on it
Don't know if it applies to the 06's, but, check the AC compressor wire for bare spots from rubbing on condensor lines or mounts. That has caused rough idle and different problems.
IF you are reading via the ECM, then yes. If you are reading by a Diprocol gauge, then no.
Nope,does not apply
Bob
