JW, the Arco's were 22 watts @ 17 volts when new in 1980, they typically lose about 10% with age, so about 20 watts. I looked around a little for used Arcos after posting earlier, didn't find any. I know there must still be some out there though, the dismantled solar farm most came from wasn't just acres, it was square miles in the Mojave desert. Environmentalists didn't like it, too much shade for the lizards. Just need to look harder, I paid $90 each for mine. A new one with the same output will set you back about $500, makes you want to consider a generator instead.
I used seven of the Arcos to run remote electrical irrigation system valves, one panel each. Had to run them thru an inverter to get 110 AC then kick it back down to 24 volts, all just to get AC. Also needed a $12 regulator at each station. The single $40 Napa deep cycle battery at each station has lasted ten years with just adding water. I've been very pleased how trouble free the systems have been, just water once a year. Batteries like solar power.
