1> You cannot "repair" (or even do preventative maintainence on) unit bearings. You must cough up big bucks for replacements.
2> The load of the truck is on 2 bearings that are very close together, as opposed to the tapered bearings in a live bearing hub which distributes to load over a wider area. A hard sideways hit can easily take out a unit hub.
3> Anytime you break a stub shaft or u-joint the chances are excellent that you will need new axle shafts since the broken parts hit unbroken ones. the u-joint ears are almost always damaged.
4> having broken "something", which setup is FAR easier to remove and remove the broken shaft(s)? Certainly NOT the unit bearing!
5> once you remove the broken shaft, the unit bearing hub is DONE. It requires the shaft to be intact and tight to hold the bearings together. A live bearing spindle setup is not affected by the removal of the broken parts.
6> Many have reported from 1 to 3 mpg improvement with lockouts. That is NOT an insignificant number.
7> The rest of your front driveline also benefits from NOT turning all the time and wearing out when you do not need it. Those parts are expensive.
8> To say that 3 pieces of axle tube pressed together is as strong or stronger than a one-piece axle tube is like claiming the 2-piece inner shaft is as strong or stronger than a 1-piece shaft. It defies logic as well as physics.
9> You neglect to mention that not only is the 2-piece passenger side shaft EXTREMELY weak, but it AND the driver side shaft on a CAD Dodge axle are really only Dana 44-sized pieces. Talk about WIMPY!! That alone is more than enough reason to want to get rid of them given the potential of the Cummins motor.
10> Why don't you link us to your website where the Ford swap requires only "minor mods". That would be very interesting reading.
Thanks for your input, but you and I will not be agreeing on much. Everyone else can make up their own minds.
