What's your favorite injector cleaner?
Closed Crankcase Breather
K&N and 4" exhaust
BG brand, 44K. It does an wonderful job cleaning injectors. It will clean up carbon on the valves and pistons also.
99' 2500 SLT, Quadcab, Long Bed, 4x4, White/Driftwood, Agate Leather, 4WAL, Auto, 241HD, 3. 54 Limited Slip, Rancho 9000's, Air Lift Super Duty's, Hallmark Cachara LTD 9. 5ft Popup Camper, Boston Whaler Outrage 17'
Well... ... add another vote for the Howes "Meaner Power Kleaner". Started using it with less than 2K on the truck, I now have 19K.
Gary... .....
01' 2500 - QC/SB, ISB w/Auto, 4X4, 3. 54 LSD, Solid White - Westin Bars, A. R. E. Cap, Bug/Vent Sheilds, K&N Re-0880 Air Filter(Scotty), Autometer Ultralites Boost/EGT/Trans/Fuel, Custom 4" Exhaust, AutoTransformed DTT TC & VB, DD III's and DD Torque Module, HX-35 Turbo.
[*]SETDR Member
[*]TU Member
[*]NRA Member
Injector cleaner: Howes "Power Kleener".....
Fuel treatment/anti-gel: Howes "Lubricator". .
I've used them both in my 1st gen truck, and now in the 2nd gen. Quality product.
Available at all truck garages and truck stops in the North East.
Frank
[This message has been edited by Frank Simkowski (edited 03-10-2001). ]
Lucas Engineering's Diesel Treatment. When I installed new DDIII's last weekend and the original injectors with 80k miles on them were clean as a whistle. Just my two Krugers ($. 50 U. S. ).
Morph.
'99 2500 4x4 QC Std transmission, Purple (usually Mud Red), 10 Disc Changer, 285x75Rx16 BFG Mudders, Amr. Racing Baja Wheels, Gooseneck hitch, 275lb King Klaw front bumper, Towing/Camper packages. DDIII's, Exhaust, TTPM, Boost Module. Fuel Pressure, EGT adn Boost Guages. Mallory Fuel Pump. (fastest farm truck around). And can't forget the hydraulic PigSticker.
1965 Chevy 1/2 ton Pickup, 350-350hp/2spd powerglide, PS, PB, Disc Brakes on the front, Tilt, Fuel Cell, 3. 73 posi.
26ft Gooseneck Flatbed Trailer, 2 horse bumper pull, Round bale Trailer.
1960 Farmal 340 Diesel Tractor.
I use the Lucas cleaner also. First time I used it was at 22K and it made a noticable difference in MPG and power. Put some in a 96 with 130k the other day and it helped ALOT.
Clark
Where can you find the Lucas diesel treatment? I have not seen it where I live. Power Service and Stanadyne is what is common, which seem fine, but when I pulled my stock injectors at 16,000 miles they were very carboned up, running Power Service about 1/3 of the time.
Lately I've been trying Marvel Mystery Oil which has worked better than expected. It runs smoother and smokes less but I don't know well MMO works for keeping injectors clean.
Vaughn
'01 2500 QC Shortbed 2wd, 6-speed, 3. 54LSD, Cab & Fog lamps, Camper & Tow Pkg.
BOMBed: RV injectors, PS Boost module, Amsoil air filter, straightpiped exh. , Aeroquip 3/8" fuel line w/tank mounted lift pump, AutoMeter Sport Comp gauges, Line-X'd, Amber turn signal conversion.
Mildly BOMBed Performance: 0-60 @ 10. 0 sec. ,
40-60 @ 5. 5 sec. ,
0-100 @ 24 sec.
I just asked the local parts store to order it in for me. That is one thing small town part stores are good for, they will get what you want when you hassle them enough.
Morph.
