Wheel Bolts - problem with Mags
Starter solenoid woes
Rear Brake Bias must go
Pretty basic problem here but I don't have a solution. I bought a set of mags/tires last winter to put on when the studed snow tires came off. They were real pretty - factory mags from a 2001? I think. anyway 265/75/R16
So today I went to do the deed. Problem - the bolts on my 92 250 are 1/2 inch with a 3/4 socket size, and it appears that the nuts I got with the rims are 9/16 with a 15/16 socket size. The bolts on mine would chew up the rims as their outer diameter is quite a bit smaller than the 01 bolts - and the 01 center caps clip onto the wheel nuts as well.
So I don't know where to go from here. I don't have the time over the summer to take the hubs apart and put in 9/16 studs, but that may be what I'll have to do.
Anyone know of any manufacturer that might make a large wheel nut with a 1/2 thread?
Anyone know how hard it is to change out the studs without a press?
I may just end up selling these and getting an aftermarket set to save the trouble. I have lots of ideas but no time :p)
THX in advance
PWR
I was just taking notes from a post over on DTR about 2nd gen chromed steel wheels, they fit without issue, backspacing is different. They take the 9/16 wheel stud and you need the lug nuts from Dodge for the center caps. The Aluminum 2nd Gen wheels fit the rear but there is a backspacing clearance issue on the fronts, a 2" wheel spacer may solve the problem but the cost is an issue IMO.
http://www.dieseltruckresource.com/dev/showthread.php?t=147764
You dont need a press to change wheel studs just back the lug nut off and use a hammer to drive them out and installing is the same the bigger the hammer the easier the job .
On lug nuts look inside any circle track maga zine you can get large diametr lugs nuts for just about any stud size .
