The year Ford you want is up to 97 or 98, the last of the square turcks before the new Super Duty body style. If I'm not mistaken, Stomp has late 90s Ford aluminum wheels on his truck (just judging by his pix). The problem with later model Dodge wheels I believe is the back-spacing. The back-spacing is deeper, putting the wheel slightly further inboard. From the front or back, it makes your truck look like a fat chick in high heels (at least on a 4x4). If you did want to use the later Dodge rims, you will also need the shouldered lug nuts, they are what holds the center cap on.
Travis. .
