I just bought a 2013 DRW 3500, will the wheels from my 2004 DRW 3500 fit on the new truck. MOPAR did NOT do what FORD did I hope. Thanks.
The 13 has 17" wheels to clear the calipers, if the 04 has 16", they won't fit.
Bill is correct the 03 year up has 17" wheels. BUT was the stud or center changed to a metric size as Ford did?
Take a wheel off your '04 and try it... then we'll all know.
Bill
I was thinking SOMEONE out there has already tried this... ... ... It will be about 2 weeks before I get back to the shop, #one on the list is to get the stock steel wheels and those awful General tires OFF the truck and install the alloys and Michelin tires. . I do anticipate some improvement with that switch. .
I have not tried but I am sure they are the same, My 2011 is the same as the 2003 and newer. You probably already know but be carful of the aftermarket alloy wheels. I could not find ANY that where "hub centric" they are all "Bolt centric" and take different lug nuts so you would have to carry 8 stock lugs so you could put the spare on. I am holding out for a factory set of Alcoas. Don't you have the Alcoas on you truck?
