More gears is about keeping the engine in its productive range.
Have to distinguish between Metro/Regional and OTR.
Consumer light duty pickups are commuter-mobiles. They don’t go far, and they’re rarely loaded to capacity. Use of engine power is favored.
Long-distance max capacity work isn’t part of the vehicle spec.
Short rpm drops between gears are needed for OTR/Max Capacity. Not otherwise.
Doing oilfield hotshot (and not having to worry about state scale houses on some runs), one learned to work with what was available. After all, even in that hard work, the average speed (total trip time versus miles; engine hour calculation) is barely affected.
Greater numbers of gears have to pay. Complexity, initial expense, reliability and estimated savings.
Engine Power isn’t the problem. Adding gears where it isn’t necessary wouldn’t make sense.
Gas motors lack cylinder pressure. The name of the game when work has to be done. Keeping them at an optimal RPM is a requirement (and fuel burn reduction pays for it).
I run Texas to the upper Midwest or East Coast with outbound loads grossing 78k. Cummins X15. 8-speed (which cracks up my friends, and rightfully so). That’s a 41k load in the box.
A backhaul of 20-30k means the rig moves almost as if empty. Engine power isn’t a problem.
— Empty, or nearly so, this combined rig accelerates like a bat out of hell.
The 13 I’d prefer it wouldn’t be so (unless skipping gears all the way up; not a good idea long-term).
As a lease tractor it’s set up for Regional work where one isn’t ever far from home (my boss grabbed it as part of a group of 10s offered in a package deal).
Does it prevent me from making the same money? (Ha!). Is my average speed lower in hilly or mountainous terrain? (Yes; it would be UNLESS spec’d for that as a constant as with all other OTR tractor-trailers which are not upgrade-friendly).
I can plan an ascent (despite difficulty by failure by all 4-whlrs to do so), but that’s NOT important compared to the descent where fewer gears has to be reckoned. (As marked upgrades or downgrades aren’t a significant aspect; this is not of concern).
The difficulty (noted by others in above posts) is in maintaining a relative constant in heavy 3,4,5-lane traffic which is Metro-only. (In a pickup you just give it throttle; big truck MUST gear-change).
Average Speed just won’t pay in short-distance out & back runs (under 300-miles total).
One eases along below the flow of traffic never changing lanes, never using throttle or brakes. Low Risk, in all ways (which is also almost highest MPG per engine hour).
The automated manuals in big trucks with 12-gears ALWAYS have a “correct” gear choice as with a 13 manual. Any condition (relative to other spec). But it’s AERO that pays the freight rate. (My 8 is same as a 13 in non-stop work).
To whine more about a light duty pickemup, you’ll need to look at the TQ/RPM chart for an X15 versus an ISB (or whatever they call the latest 6.7). Full EEC and a variable-vane turbo make BOTH more capable than what was available circa 1995.
My ‘04 Triple Nickle with the mans trans does what needs to be done. I couldn’t care any less you pass me on an ascent, as I’ll pass you ALWAYS in the need for fuel (the combination that works).
Sure, it’s be nice to have an even higher SECOND OD gear for Solo, but it wouldn’t ever pay for itself.
I wonder (and not too hard) if the correlation between wanting more gears and lousy tire/brake life is high.
A Diesel engine is meant to WORK against a load. That’s a panty-twister for the 40-60k tires & brakes crowd.
Yet more proof a diesel pickup was their wrong choice. Dodge has to build these to fulfill the spec. And put up with the softball daddies (ATVs on a trailer) hauling ass down the Interstate. 20k in options and another 15k in aftermarket. (Clowns).
Show us using Engine Hr versus Odometer Miles over the past year where AVERAGE Speed was unduly affected by not having MOAR GEARS.
As to MPG, start with showing us the ABOVE 30-MPH average (mines 47) that you’ve REMOVED bad driver habits as a source of unnecessary fuel burn. (All miles divided by engine hours. You log all fuel purchased, right?).
At 58-mph on cruise control, level Interstate, what’s the TESTED 200-mile round-trip average MPG?
Never tested it, did you? (The spread between worst and best drivers — professionals — is nearly a third). The only MPG “problem” is the driver. Doesn’t know how bad he actually is, and has never taken steps to rectify even the worst of it, as he DOES NOT KNOW that which his truck is capable. (All MPG contests are against ones self).
That one-third spread among pro drivers from bad to acceptable is your “extra gears”. (And can be improved by simple aero).
“Up the hill . . “ (seriously?).
