4. 10 but 285/70R19. 5 I'm a touch over 2200 at 80mph.
BTW, I have a spreadsheet that can calculate what RPM vs. Speed you will get by changing wheel/tire size, before and after listed on the same sheet.
It's free for the asking. It's an Excel spreadsheet so obviously you need Microsoft Excel. Email or PM me and I'll send it to you. You can see an older version of the spreadsheet with my truck pictures.
It's very accurate when you use the tire manufacture's "Revolutions Per Mile" which is part of the spec for any tire (at least it should be in the spec from the manufacturer and a few are included on the spreadsheet). It has a separate sheet for using just the tire size if you don't have the manufacture's RPM spec. , but it's not very accurate (but in the ball park).
It also will calculate your effective gear ratio when changing tire size, can compare two different rear end ratios, tires, etc. Also gives you speeds for your top 4 gears (all of them with an Auto). FYI.
-Bruce
