I just bought my truck a month ago, and not knowing what kind of maintenance has been done I've been going through it. Today I figured I'd change my fuel filter for the first time. I bought a Haynes manual and a fuel filter and went to work. I got the filter changed filled the canister at least 3/4 full with new fuel put it back together and following the Haynes book proceeded to bleed the fuel line. It said to loosen the fuel supply line at the injection pump, start to crank the engine but dont start it then return the key to the on position and watch for fuel to come out of the fuel supply line. After atleast 20 attempts fuel still hadnt come out. So I took the filter back off and there wasnt a single drop more fuel than I had put in there. So thinking back to my days as fleet mechanic working on International 7. 3's in Ford Super Duty's I tightened everything up put the accelerator pedal to the floor and cranked the engine for about 20 seconds with no start, gave it a minute to rest and did it again, after about 10 seconds it started and seems to be running fine. I've alot here about lift pump problems Is it possible mine isnt working but the truck still runs okay?
