Got in late last night. This morning I noticed a long rubber tube dragging the ground under my truck behind the rear axle.
There is a junction block on the top side of the axle (drivers side) with several brake lines running to it. This rubber tube(about 24 to 30 inches long) is plugged in to the top of this block. The other end was dragging on the ground. Everything is still working fine.
My question is: Where is the other end suppose to go? Nothing is leaking. I assume this is some sort of breather tube???
