Engine/Transmission (1994 - 1998) where is your #10 plate set????
J
2nd Gen Non-Engine/Transmission 98 12v dually
Engine/Transmission (1998.5 - 2002) B1 turbo questions
I have dd2's a #10 and 3kgsk PDR hx35/14 and 4" exhaust
the truck seems to run very high egt when crusing on flat ground,no head wind, and less than 5 psi boost ~50 mph
the plate is almost all the way back and the afc is all the way fwd
smoke is ok but I like the power when the #10 was in the stock position and a little ahead but the egt's start to worry me
Harry@ Piers said not to exceed 1000egt while towing but what about just driving arround at the speed limit when the boost drops whats an acceptable max egt??
I'd put it in the middle, a #10 and DD2's is a good bit of fuel but if your not at 10 psi of boost and hard down on the throttle your not using the plate much if all, on towing just don't do extended runs over 12-1300, short blasts like racing even in the quarter are not an issue.
Jim
Hey, while were on the subject of the 10 plate, will a factory clutch hold with a 10 plate moved all the way back?
Brandon
You might want to check your gov arm adjustment. Any time you move your plate around it effects the gov arm to ramp position. I have changed mine enought times to realize it does change the fueling rate. Thats why they have profiles. Also check your preboost adjustment on the rear of your afc. Too much preboost will effect your egt as well at low rpm. Hope this will help you. Good luck!
A #10 was the first mod I did after gauges and still had the stock clutch with about 115-120 miles on it. I had no problem with the clutch and the plate in the stock position but I did put my current clutch in about 10K miles later.
Just don't be stupid with the shifts ie, no power shifts.
Mike
ok fellows,
I think I’m gonna give the 10 plate a try, and if that proves to be too much, I will put the stock one back in.
Brandon
Originally posted by SmokinU
ok fellows,
Brandon
Once you try it, I don't think you'll want to go back to stock. You'll most likely justify other mod's first. :D :D
Lowell
That is exactly what I am afraid of:D
Oh well that expression "you got pay if you want to play" comes to mind right about now.
If I get a 10 plate, is the governor lever supusto hit the bottom of the plate then ride up to the center? Or is it supusto have a straight shot to the center of the plate profile? Either way, I think my governor lever will need to be adjusted again:{
Brandon
