Where To Mount The Attitude Monitor??
gages for 05 dodge cummins
I have the Juice / Attitude setup and have been using the skeleton bracket that came with it for mounting the monitor on the dash.
I have seen ATS's mounting bracket for the monitor which mounts to the right side of the drivers sunvisor.
Has anyone come up with something that looks factory? Even something that just looks better than having it 3M'd to the dash.
Pictures would be helpful.
Thanks,
PA
They make an A Pillar mount and I did one for a friend.
Personally I didn't like the look of another piece over the top of the OEM Pillar.
Also available is an overhead pod you can paint to match that mounts between the mirror and OEM console.
The size of the Attitude looks as though it would go in the Cubby nicely with a small filler plate on each side.
Here is the Edge A-pillar mounting bracket. It is ok and does match the interior A-pillar well.
Different angle.
take a look in my readers rigs and you'll see my creative setup i bought the srt 10 pillar and mounted my attitude with 3m auto body dual sided tape awesome holding power but easy to remove without damage if necessary. :)
DJamrose,
Nice job. I actually like that much better than the Pillar piece. You get to keep the factory lower handle bolt that is more secure than the aftermarket piece.
I placed min on the steering shroud. I also ran my attitude cable through the firewall insteadon through the fender well area. Easier to look at with out prying eyes looking in and seeing whatcha got like the pillar. I like it being easy to remove for dealer service issues.
all i need to do is pull the two pillar bolts out and put the factory one back in place super simple i also ran my cable through the firewall just looks more professional 11 mins to remove the whole setup :) Oo.
