Done deal
Just got done with diff. fluids change.
Here's what I did... ..... truck was sitting for 8hrs. I made my own diff. dipstick and measured how much I had on front and rear diffs. before the fluid changes.
Truck sitting on level ground rear diff was 1/2' below fill hole.
Front diff. was 8oz overfill
Factory specs according to owners manual was;
rear diff 3/4" + or - 1/4 below fill hole
front diff 1/4 + or -1/4 below fill hole
I have the dana 80 for rear and 60 front.
Rear took exactly 2oz shy of 4qts which is almost 8 pints.
Wheaties is right about the book specs which calls for 10. 1 pints, but this was the actual amount I came up with.
Front took about 3qts level to fill hole.
Royal Purple rocks, didn't need any modifier. I had a short road test with truck and some tight turns and can't feel the difference between the fluid changes.
Now the rear diff. fluid was dirty and black while the front didn't look like it needed a change, it still was clear. I have 22k on truck right now.
So far I'm happy with the Royal Purple and saves the hassle for adding modifier. For the front axle I used the recommend 80w90 gear oil which I used Castrol. I felt there wasn't a need for synthetic up front.
One little tip I picked up from Tdr was to jack up the rear end on one side at the time to drain the fluid from the axle tubes. I must admit I was amazed how much more fluid drained from the axle. Good tip and recommend it to all.
Fred.
