Which Hitch
flow restriction on 70214AA upgraded steering gear?
DTC code P0234 Turbo overboost
I'm looking for a dual pivot non slider hitch that will bolt on my 2005 Dodge without drilling holes in the frame. Any ideas ? Not looking for an expensive air ride unit as I will likely upgrade the pin box if necessary. The important feature is NOT drilling the frame.
My Reese Elite has a frame that goes under the bed and clamps on to the frame. It is a very strong set up. When the hitch is removed the bed is clear however this hitch blows your budget. I don't think you get the set up you want for low bucks unless it is a poor hitch. When I got a hitch for my 03 there were some brackets available that bolted on using existing holes. I have never compromised on a hitch as I do not want a failure.
Here is a Curt no drill kit that allows the standard mounting rails for 5th wheel hitches. Check out Craigslist for a hitch. I see them all the time at good prices. I paid $150 for a Nice 20,000lbs dual tilt Reese hitch that was like new off Craigslist
http://www.etrailer.com/Accessories...tml?feed=npn&gclid=CPH-6cH5lbgCFS9dQgoduyIA3w
Reese kit, I don't know anything about this set up. Had the Curt style on my 2005.
http://www.americanrvcompany.com/Re...all-Brackets-No-Drill-Dodge-Camper-Trailer-RV
Have you checked out DSP? They are made in Western Canada and are available at places like Gregg Dist. I have used their products many times, but not a fifth wheel set up so you would have to contact them first. David
