Which Power Boards?
OBD2 iOS code reader apps for iPhone
Level kit
Iam considering installing power running boards on my truck. Been looking at PowerBoard-NX and AmpResearch power step.
Looking for best ground clearance. Trouble free operation, even running off road. No uneven up position alignment issues after wear in.
Any and all recommendations and comments appreciated.
Best,
Joe
Best Top and AMP are very similar. Amp step original with less warranty. Bestop a copy from amp step partner trouble (afaik).
I have Bestop going on 8yrs or so. Have to replace a motor ( it is erratic and sometimes requires a second run at it.
Customer service with technical was great and part direct from Bestop was 1/2 price of all other sources I found incl amazon.
( have new motor but have not replaced. Proved motor issue by swapping side to side)
Make sure you get option that uses magnets to detect door positions. Much easier install and the two types not interchangeable.
Best mod I ever did , and if I ever replace truck, the new one will have same.
Boards tuck up inside rockets and not apparent they are even there, yet drop to a lower entry height than solid mount bars etc.
HTH
