My friend has an 04 that smokes white only at idle. A mechanic drove it and says there is nothing wrong with it. Is that true or could it be an injector failing?
If an injector needs replaced he's thinking of changing all of them to the 50 hp Dynomite diesel ones for the 2 mpg increase. Good idea?
Also do the injector bodies need replaced to upgrade or just the nozzles? Explain if you can when to change nozzles or bodies? I don't know much about injectors. Thanx
