Engine/Transmission (1998.5 - 2002) White Smoke???
I started my truck this morning and it started pouring white smoke!! The truck idles fine and runs fine but no more black smoke its white now!! New turbo, injectors, head gasket and pump just resently!! No codes present!! Ask any questions!! thanks will
sounds like the timing is either really advanced or the head gasket is blown
doubt you feel like talking about it right now but how did you like that turbo???
Don: I did a compresion test and its great! so im thinking it the injection pump!! I really like it!! I had a 16cm housing and it was to laggy so I went to a 13 and it spools so much better!! I highly recommend it with the 13 for the 24v trucks!!
CW: its like low 80s!! Not cold enough to do it for 30 min!!!
good deal will. i have heard of guys under torquing the arp studs and killing new gaskets as a result. glad that is not your case.
i just got one of the htt ss housing turbos myself. its on a first gen truck tho, so not near the power you are seeing. its a 62/65 13 and i am not sure i went the right way. you probably have a 71mm turbine crammed into the thing and it probably works great in that config...
