I am in a quite rural area of KS and need to know who I should try check the timing on my 93.
There is a local caseIH dealer, almost thought of aslking them since there is alot of case farm equipment with the 5. 9 cummins in it.
Lincoln NE and Salina, KS are about an equal 2 hour drive. Topeka is doable if anybody on here knows of good shops there.
Just have been doing lots of reading how the timing can really affect power. I also have the "wet dog" shutdown that I was reading about in some older discussions.
Maybe I am just reading to much :-laf
Also I think I have gotten the grasp on this fuel pin diaphram adjustment after reading up quite a while on it. one question yet is there a seal under the cap you remove with 4 screws that is going to need replaced? Also does this adjustment affect your overall power or just the rate at which you increase the fuel? In other words how much can I play with this stuff before the stock clutch and getrag don't like it anymore?
My pump already has no cover over the smoke screw, so I don't know what somebody might have been upto in the past.
