rbattelle
Okay, got a decent response from the Powermaster:
I thought that was pretty interesting. Whoever that Powermaster is, he knows his stuff.
Ryan
Cummins Powermaster said:We've had a misunderstanding on two points. We weren't saying that without a grid heater it would not start below 40 degrees. We were just saying that the grid heater kicks on at 40 degrees and so the logical answer was 41 degrees.
The second point is that we didn't know your operational parameters. The ECM on the Dodge product is not a Cummins ECM. Our diagnostic software INSITE won't communicate with the Dodge ECM so it is entirely possible that yours is set to 65 degrees. Also we assumed 40 degrees because all the old mechanical engines and other electronic engines were set to come on at temperatures lower than 40 degrees F.
Lastly, and perhaps this answers all questions, even the origional one the best, is that all our engines are rated downt to -15 degrees fahrenheit. That isn't to say they won't start lower, but that is just what we test down to. This is the rating for all the pumps in question and we do not have a published minimum start temperature. This kind of fact begins to depend on things like oil type in engine and cloud point of fuel, and cold cranking amps of batteries, etc.
You may be interested to know that the block heater will warm up the engine 40 degrees from ambient air temps. So at 0 degrees the engine coolant would be about 40 degrees, or at -15 up to 25 degrees Fahrenheit.
Ryan
