jeepit said:
On the intank reto-fit, what is that block where the old pump was located. Just to cover where old pump was??
Yeah... the block does nothing more than take the place of the OEM LP. No need to change fuel lines or fittings for the dealer doing the install. It accepts the regular banjo fittings like the lift pump.
I'm still thinking about tossing the block and putting a new LP back in place. I just changed fuel filters since getting the truck back from the dealer. With a clean filter. . I did pick up a pound or two of PSI. It doesn't drag down near as fast either. I'll keep two spares with me at all times.
Here are my pressures with a new filter:
1. When I bump the starter (just to get the pump running. . not the engine) I get a steady 8. 5psi
2. Engine running at an idle... 7psi
3. cruising down the road empty... about 4 or 5psi
4. WOT with or without a load... it now stays around 2psi
I'm sure I can suck it down to zero with a heavy load going up hill or something. Just have to make sure I don't do that. What a shame! Now I have to drive it like there's a competitors engine under the hood. Gotta baby it under certain situations. Complete BS.
Maybe we're all paranoid. Maybe this new intank pump will cure everything. I'm just having a hard time figuring out how 2psi under load helps the VP44. If Cummins had only put a real injector pump on this engine (you know... one you don't read about everytime you check into the 2nd generation forum) this would have been a great rig. I have absolutely no complaint with my Dodge. . other then the constent fear that the VP will give out again (with no notice by the way).
With 25K miles left on the warrenty I guess I should just run the snot out of it and "damn the torpedo's"..... or sell it now. I'm really bitter about this whole thing. I've gone from having all the faith in the world in this engine to having none... zero.
Mike
