Swamp Donkey,
I hear ya. Once I took out the torque plate and peered 6" down into the pump, I almost put everthing back together. I said "you gotta be kidding me"
Drawson,
Here are some more "in depth" tips.
I went into the pump from the torque plate. Some guys go into the pump from the plug on the side that's saftey wired. You have to remove the fuel shutdown solenoid. When I went to remove it mine fell apart because the rubber boot had rotted.
I would go in from the top like the directions say, at least your first time.
Get yourself a good strong rare earth mechanics magnet with a long reach (you probably already have one)
Put a breaker bar and 17mm? socket on your alternator. Bar the engine over with one hand while watching the governor housing, stop when it looks like you can get a str8 shot with the calipers to the spring pack. You don't want the springs packs pointing str8 up. You won't be able to work on them. You'll see what I mean. Go too far and you'll have to go around again. You can't go backwards. The belt will slip.
Measure the distance from the center spring stud the the retainer. This sounds easier than it is. I had to take about five measurements to feel I was in the ballpark. (first time with calipers) Stock yours should be about . 060. Maybe a little more.
I used a medium long screwdriver the loosen & tighten the retainers. Just put the tip in one side of the slotted retainer and turn. I have never had a problem. Piers told me this is how he does it.
Put your magnet on the retainer when its almost loose. Pull it out, set aside.
One problem I did run into when I went back in the replace the shims under the BIG outside spring I removed (not supposed too).
The rod that connects the rocker to the control rack was slightly in the way so the smaller middle springs couldn't be lifted straight out. Rotating the governor housing won't help. You'll have to kinda tilt them to the right and lift them out. Same thing when you reinstall them.
Use magnet to pull the 3 middle springs out, one at a time. Make sure all the shims come out to. Mine came out with the springs. They were stuck to the bottom of the spring with oil.
If you want, you can take out the BIG spring and set it aside. Leave it in the pump. I left mine on the right. Its too big to loose. It may be easier to work with it out of the way. Don't lose the shims that may be stuck the the bottom. You really shouldn't need to do this.
DON'T remove the shims under the big outside spring that contols the idle. This one we don't replace. The directions say to remove all shims. I screwed up there. Idle speed dropped by 300 rpms. Had to go back into the pump next day and replace them.
After the 3 middle springs are out, use the magnet to pull out the OE spring seat.
Drop the new spring set into place with the magnet. Push it off the magnet with a long screwdriver.
Reinstall the big outside spring if you removed it. I started by installing the biggest spring in the kit. This will help keep the smaller ones in line. Stick it on the magnet and drop it in. I used a long medium sized screwdriver to "push" the spring off the magnet. The spring seat and the big spring keep them in line nicely. Its hard to get one not seated correctly.
Repeat with the next 2 smaller inner springs.
Next put the retainer on the end of the magnet. Slip it on the center stud. With the magnet still attached to the retainer, start screwing it on with you screwdriver in the other hand.
Get it tighted down some what and measure the distance from the stud to the reatiner. Try to get it to your factory height.
Rotate engine 360º via the alternator, while watching the governor housing, and bring the other spring pack to the top.
Repeat steps above.
Make sure both spring pack retainers are at the same height. Its easy because each click on each retainer is the same distance on both sides.
If you drop a shim, fish it out with your magnet. It'll probably be hidden in the oil. Piers said he's dropped a few. No too hard to get out.
This is really an easy job. A little intimidating at first.
If you are happy with your settings the first time, consider yourself lucky. If you have to much pre-load on the springs, you truck will go from idle to 1500 rpms in an instant. Not pleasant to drive. Tough on drivetrain parts too
You will want to go back into the pump and back off the retainers maybe 1 or 2 clicks. Not really any need to remeasure the distance, since each click is the same distance on both sides.
You don't want a "soft" pedal either. A setting of . 030-. 040 will give you a soft pedal. You'll get a real crappy idle. I hated the soft pedal. My truck is set @ about . 055.
You are better off with a touchy/sensitive pedal than a soft pedal. You'll get a much smoother than factory idle too.
It may take some getting used to with the pedal alot more sensitive than factory. Try putting a stronger throttle return spring on if you want.
You'll love the new governer springs. No more defueling @ 2300rpm. It pulls as strong @ 3000 rpms as it did at 2000 rpms. The truck will have a new personality from idle to past red line. You'll swear the truck has more torque and HP.
I know You're no dummy when it comes to mods. I just wrote down everything I could think of. Maybe other novice members could use these tips.
Good Luck
Let us know how you like the new springs.
Members, If you see something in the above post that is incorrect or have a better idea, please correct me.
