"He told us where he was getting his readings!!!
QUOTE:
"I also expect to see LESS pressure on the guage when the banjos are removed--if indeed they permit freer flow downstream of the LP. "
LP = Lift Pump!
That means downstream of at least two banjos. When those two banjos are removed in place of -6 fittings the pressure will rise at that point. I have done this test. "
SURE - because you've just "opened the faucet" more, allowing more FLOW and pressure thru the LP, against the downstream obstructions that are STILL THERE! Naturally, the pressure at that point WILL increase - but if you THEN REMOVE or reduce the remaining downstream obstructions, and assuming there are no other restrictions beyond, pressure will REDUCE to some LOWER value, since there's nothing LEFT to restrict flow! Of course, we know THAT isn't totally possible, since various internal elements of the VP44 ITSELF restrict total LP pressure/flow, regardless of various external fittings used... What we DON'T know, is exactly WHAT the maximum flow rate is possible/recommended directly into the VP44 at, say, 16 psi or so - and WITHOUT knowing that, various efforts to increase flow above stock values are sorta "shots in the dark"!
Tho we HAVE heard vague refferences to 18-22 psi as being limits of internal VP44 seals...
BUT, if all we're REALLY interested in for a "feel-good" sensation with fuel pressure, all we need do is insert a 1/16 inch restriction in the fuel line immediately AFTER the pressure sensor, wherever it's installed - THAT will deliver a reading near the maximum the pump is capable of delivering - AND, most likely, a soon destroyed VP44... OTHER restrictions downstream from the sensor do EXACTLY the SAME THING, just to varying degrees, depending on how severe they are!
"IMO the only place to measure fuel pressure is at the VP44. At this point the pressure will benefit to a greater extent from the removal of even two more banjos (restrictions) in the filter housing. "
No doubt... And it is CERTAINLY the most critical point for proper operation and life of the VP44!
MY comments and observations have been directed primarily towards the beginning post in this thread - concerning Banjos used by DC at the VP44 itself:
"Does anybody have a clue as to why DC/Cummins/Bosch uses banjo bolts instead of 90deg AN fittings on the VP44??? Is there an advantage to banjos that I am unaware of?? Were they just on sale when the VP44 was designed?? Just curious. "
- tho' we HAVE expanded to various elements elsewhere in the fuel system. I certainly agree that decreasing restrictions PRIOR to the LP will allow its greater performance/efficiency, and presumably, higher resulting pressure.
BUT, whether pressure increases will occur DOWNSTREAM from the LP, at the VP44 itself with larger connectors at that location *only*, I seriously question. And it probably isn't even a critical issue, since expected increased FLOW in itself is benefit enough to justify the change, especially if OTHER system improvements are made as well...
"Who have you seen taking pressure readings prior to the lift pump? What would that serve? The restriction has been identified as the banjo fittings in this topic. "
YUP, originally concerning those AT the VP44 itself, as I pointed out above! MY comments regarding pressure relate entirely to to what occurs AFTER/beyond the greatest restriction in the total system - regardless of where the guage sensor is installed! After all, guage pressure at ONE point in the syatem CAN be substantially DIFFERENT at another point, depending on restrictions present along the fuel's path!
I'm not thoroughly familiar with various differences in fuel systems year-by-year in the later trucks - but based on comments and instructions on some fuel pressure installations, THOUGHT it was pretty common practice on some older trucks to install the pressure sensor at the fuel filter - either before or after the element, rather than directly at the VP44 as the latest trucks now do...
In any event, it's for SURE that removing as many restrictions as possible WILL improve fuel flow, and most likely increase overall system PRESSURE as well, if done thoroughly - but increasing only PORTIONS of the system, while leaving significant OTHER restrictions in place SERIOUSLY compromises the other improvements - and THAT has been my intended primary point!
And hey - this is intended as only a DISCUSSION - not a debate or argument!
