Steve,
Thanks for the idea... ... ..... but, I someone pressure tested my complete system for just what you suggested... ... ... . one small leak was detected coming from my boost gauge fitting. Still only 32 psi on the highway.
Update, I pulled the IAT sensor. 65k miles, there was an oily surface on the plastic end. I cleaned it off with carb cleaner, than used some compressed air to make sure all the carb cleaner was off. I checked it before I cleaned it and after with a meter, 10k ohms before 12kohms after..... but IL think my meter may be off.
Test drove after, no changed was noticed... ... ..... anywhere.
I think my next course of action will be to go to a Cummins shop and have them throw a scanner on it. Hopefully they will say I have a soft program in the ECM... ... ... .
Thanks again. I will keep everyone updated as I find more out.
BTW, I hear that lower boot is VERY expensive!
