Apparently so and well. I pulled one from a 93 Ram that I had messaged a bit prior to replacing with another modified pump. The 4BTA pump ran very well. Someone must have swapped the high pressure head cuz all 6 cylinders had fuel.
Pump Numbers as follows;
Engine CPL 986 (4BTA)
Bosch # 460 424 079
Cummins Pump Part # 391 3443
There is a hand stapmed # on the far right of the area where all the ID #'s are located. It must refer to the 6-Cylinder head installed.
Anyone seen one of these on a Dodge Ram?? Wonder if the 1993 Dodge Rams had OEM pumps replaced from the dealership
Bosch # 460 424 079
