I put an '02 motor in mine and it was suprisingly easy. The bracket that the fan bolts too was different. I had to use the one off the first gen motor. I also changed fittings on the power steering pump. First gen motor mounts are still fine at higher hp level. Throttle cable has to be changed, but is easy. You will need to buy a relay for the fuel shut off . The one on the p7100 is a bit more substantial.
