Wiring diagram for 99 from
This is from the
www.the12volt.com
1999 Dodge Ram Pickup Security Information
Constant 12V+ Pink/Black or Red Ignition Switch Harness
Starter Yellow or Blue/Yellow Ignition Switch Harness, Must Add Relay for Remote Start
Ignition Dark Blue Ignition Switch Harness
Ignition 2 Black/White Ignition Switch Harness
Accessory Black/Orange Ignition Switch Harness (Heat/AC)
Tach Black/Gray PCM Passenger's Rear of Engine on Firewall
Neutral Safety Wire Black/White (-) Ignition Switch Harness
Brake Switch White/Tan Brake Switch or Ignition Switch Harness
Trunk Pin n/a
Parking Lights Black/Yellow (+) Driver's Kick Panel White Connector Driver's Kick Panel
Head Lamp Light Green/Black Steering Column
Factory Disarm Light Green/Orange (-) 24 Pin Connector behind Driver's Dash
Door Trigger Yellow (-) Driver's Kick Panel White Connector Driver's Kick
Door Lock Orange/Purple (REV) 10 Pin Connector Driver's Kick Panel Reverse Polarity
Door Unlock Pink/Purple Driver's Kick Panel
Driver's Lock Orange/Black Left Kick Panel
Driver's Unlock Pink/Black Left Kick Panel
Passenger Unlock Pink/Purple Left Kick Panel
Horn Wire Black/Red (-) 74 Pin Connector behind Driver's Dash
Windows Up LF=Light Blue, RF=Brown/White
Windows Down LF=White, RF=Purple/White
