2nd Gen Non-Engine/Transmission Wiring Question
Engine/Transmission (1998.5 - 2002) Got the bombing bug!
I am wiring a relay for the +12v to the trailer plug. Were is the best place to get key switched power under the hood? Or is it easier to connect inside? I already have a fuse tap in the radio fuse for the gauges.
Thanks. .
Jared
Wiring diagram for 99 from
This is from the www.the12volt.com
1999 Dodge Ram Pickup Security Information
Constant 12V+ Pink/Black or Red Ignition Switch Harness
Starter Yellow or Blue/Yellow Ignition Switch Harness, Must Add Relay for Remote Start
Ignition Dark Blue Ignition Switch Harness
Ignition 2 Black/White Ignition Switch Harness
Accessory Black/Orange Ignition Switch Harness (Heat/AC)
Tach Black/Gray PCM Passenger's Rear of Engine on Firewall
Neutral Safety Wire Black/White (-) Ignition Switch Harness
Brake Switch White/Tan Brake Switch or Ignition Switch Harness
Trunk Pin n/a
Parking Lights Black/Yellow (+) Driver's Kick Panel White Connector Driver's Kick Panel
Head Lamp Light Green/Black Steering Column
Factory Disarm Light Green/Orange (-) 24 Pin Connector behind Driver's Dash
Door Trigger Yellow (-) Driver's Kick Panel White Connector Driver's Kick
Door Lock Orange/Purple (REV) 10 Pin Connector Driver's Kick Panel Reverse Polarity
Door Unlock Pink/Purple Driver's Kick Panel
Driver's Lock Orange/Black Left Kick Panel
Driver's Unlock Pink/Black Left Kick Panel
Passenger Unlock Pink/Purple Left Kick Panel
Horn Wire Black/Red (-) 74 Pin Connector behind Driver's Dash
Windows Up LF=Light Blue, RF=Brown/White
Windows Down LF=White, RF=Purple/White
Thanks guys...
My wiring inside was kinda closed up but it seems my pyro has a problem so I'm gona have to open it up anyway :rolleyes: I guess I'll redo it with future expansion in mind. I need to leave tomorrow and was hoping there was someplace easy under the hood I had missed.
Jared
Gifford
Good info on that site, I saved your post in my Cummins folder for future referance.
Chipstien
12:16? Dont you ever sleep:)
Jared
