Won't get over 60 in 5th gear
Headlights Inop
Radio backlight
I assume the truck doesn't have a fuel pressure gauge. It worth having one installed.
Loaded or empty? What RPM? 5-speed or 6-speed transmission? Automatics are 4-speed.
A clogged fuel filter will cause problems but usually it will stumble from a lack of fuel.
In 5th gear at 60 mph the engine RPM will be low and there won't be much turbo boost. That will limit any get up and go.
Have you also checked the air filter and boot hoses? A clogged or restricted air inlet will cause similar issues and create a decent bit of smoke. Is there excessive black smoke?
