It does turn green after you press the exhaust brake button the second time. Pressing a third time turns it off completely.
Yes... it turns green.On a side note, can anyone confirm for me if the exhaust brake indicator in the dash actually turns green when in auto mode like the manual says?
Depends on what model EVIC / dash you have....On a side note, can anyone confirm for me if the exhaust brake indicator in the dash actually turns green when in auto mode like the manual says?
This................the evic in the tradesman does not turn green. When the button is pushed a second time a large Icon appears on the EVIC for about a second
GC, I have read your concern about the EB and I myself have tried to get to the bottom of how this thing works....I can not get my EB to come on under 30 MPH. Some say its a RPM thing and others say it’s a MPH thing. I think it’s both....I know my EB goes off or disengages under 1,100 RPM and it will not engage(or come on) under 30 MPH. I have tried TH on and off, still wont engage under 30 MPH. It’s frustrating when I tow my trailer down a hill that will not allow me to go over 30 MPH. I have also tried to keep my RPM’s above 1,100 RPM while going down a hill at say 20-25 MPH and no help from the EB. It sounds like your EB works a lot like mine. When I’m going over 30 MPH and RPM’s are above 1,100 all seems well. This must be the way it was designed to operate not sure. GC, I see your in Woodside Ca. not far from you in Redwood City....
GC, my EB will stay on under 30 MPH and above 1,100 RPM’s if it starts above those two parameters, but if it goes off and I’m under 30 MPH but above 1,100 RPM’s it will not come back on. It’s sounds like the same thing your having, there’s no telling when it will come on. Forgot to mention on my last message, I had radio problems as well. I would lose all my presets and the clock would not change after I started the truck. I also had the whole screen go black and the radio would still be playing. I could not use any controls when it would go black...I finally took to the Burlingame dealer and they replaced the entire unit. Luckily it went black on them when it was at the dealer(that never happens). They decided to replace the whole unit. After the new unit was installed, I haven’t had a problem. I had some problems getting the UConnect to work after the new install, but got that worked out as well....
Soooo.... update on the new firmware in the 8.4AN. No dice, still the same problem. Driving along listening to music, the radio just starts scrolling through the inputs. Mute it, it unmutes and starts again. Put it back on the input you want, few seconds later it starts scrolling through the inputs again. If I could give this thing back to Dodge I would. Ridiculous to have so many issues with a brand new vehicle!
If it starts scrolling through the inputs most likely the Media Hub. Try plugging a USB device into it and see if it makes a difference. If it does it pretty regular the dealer can disconnect it and confirm the problem goes away.
