Let's put this back into the perspective stated earlier - do those LS1's also have the cam overlap suggested - and are they using forced induction?
Perhaps in the range of a STOCK, non turboed LS1...
And what are the full details of that engine you speak of, what valve overlap, and how much "not to be bragged about" boost at power peak?
Keep focused, that MY point in this discussion is my challenge to the suggestion that significant measurable BOOST is undesirable, "Nothing to be bragged about", in a competition engine, and that lots of valve overlap to purge cylinders, plus improved head flow rates are PREFFERED over boost if a choice is to be made.
All my earlier exposure to the theory of intake/exhaust flow in engines has been that valve overlap is a potentially useful tool that encourages improved total charge flow thru an engine as it operates, providing cylinder scavenging and enhancing cylinder filling as the exhaust valve closes and provides a small degree of artificial forced induction/cylinder pressure due entirely to the increased flow rate/speed created by valve overlap.
That's on a NORMALLY aspirated engine!
Things supposedly are different on a forced induction - turbocharged or supercharged - engine. Good flow rates thru use of intake/exhaust manifolds, as well as intake/exhaust head ports are certainly still good to have - as well perhaps as a relatively SMALL degree of valve overlap - but with the characteristic benefit provided by forced induction, large amounts of valve overlap for cylinder filling is not only largely unnecessary, it can actually bleed off a large degree of the desired cylinder charging and volume of additional charge mass the forced induction was installed for in the FIRST place!
Sorta like designing a big balloon with an included extra hole to bleed off that "undesirable" pressurized air we just worked so hard to get inside! :-laf
