Simply incredible,I can't believe it!!! I am so happy with the results! You probably saw my recent post about blowing out the clutch slave cylinder. Just so you know,I put a hi-perf clutch (to remain nameless) in my truck that had such a stiff pedal,it took a gorilla leg to operate it(well,pretty close to it). Since it seems very few of these actually break,mine must have been a weak one,then combined with a strong clutch,well you know the rest.
I called up Napa to see if they stock just a replacement slave cylinder. They didn't have one listed for a '00 6spd,so I told him to give me one for a '96-'98 5spd... Napa United P/N 360-051.
With the help of jmbrowning,we took out the original cylinder and compared it to the new one. The Napa cylinder is made my the same company that makes the Dodge one! All the markings are the same,and made in the USA. There is one BIG difference... the NAPA one is about twice the diameter as the original,while keeping the same bolt spacing. The install went easy,but had one small snag for the 6spd. The hole where the hydraulic line fits in needed to be reamed just slightly. I'm sure the 5spds don't need to modify this. Everything bolted up perfectly and bleeding the line was easy.
Now for the big suprise... .
I was shocked to discover that I now have one of the softest clutch pedals I've ever felt! It's softer than a stock ETH pedal. I love it! No more gorilla pedal! Also the clutch engages more toward the floor rather than at the top of pedal travel. Since this cylinder is twice the size,that means there is more volume of fluid to actuate the clutch... meaning less pressure. I didn't know this would happen,but I like how it turned out. Now let's just hope it lasts!
-Mike
'00 2500,QC,4wd,LWB,Dark Garnet,6spd,3. 54lsd,SLT,DD stage II,Psychotty air,10-level PM3,Jacobs ebrake,Isspro pyro & boost gauges,2wd-low,Airoquip fuel lines,Smittybilt nerfs,BFG 285/75 AT's
'95 2500,Reg-cab,2wd,LWB,White/Star silver,Automatic,3. 54,SLT,Michelin 265/75
-Mike
