Wrecked this morning-Steering Upgrade Question
Diagnosis Time - what's failing that causing this?
Easy to deal with pacbrake vendor
This morning driving to work in the dark I hit some hogs. I killed two of them, may have hit 3 or 4. Anyway, I had done the Mopar steering upgrade kit with pitman arm. One of the hogs ripped the pitman arm off the steering box and I also broke a tie rod end so they're going to need to replace all of that and I want to make sure I get what I had. Is the steering upgrade off of an '09 truck?
Where I bought it online it said it was called an 08 upgrade but was not ever clear if the 08 had these parts on them or if these parts were intended to upgrade the '08 to the '09 setup.
Thanks guys.
I think the upgraded parts started coming on trucks in '08. 5. If you order parts for an '09 I think it should be good.
The part numbers of each item are listed on this site from previous posts.
--Eric
