Clearly there can be something better behind the Cummins for a transmission. My Aisin has been problematic shifting from day one, many software updates that have improved but not completely solved it... The Chrysler transmission offered for 2018 IMO was a slow shifter combined with the low output engine cal to get the memo to get the right gear and finally get moving. But the Aisin is still unrefined for shifting given the many software updates even on late model newer RAM's. IMO it's a production tolerance problem where some are not affected and others are too tight to let the current gear go for another.
My families other lemon GM ride lets me hear all about the loved 10 speed behind the Duramax. It's not the number of gears: it's how well it uses the gears and ability to be in the proper gear without the "Who is on 1st" engine stalling DRAMA my Aisin has. Sigh, I got to go raise hell with Stellantis, yet again over yet another item, to maybe get this fixed as my RAM dealer(s) get nowhere.
That style of transmission service, and long fluid life, was introduced a long time ago on other platforms. Toyota started using it in with the 2003 4Runner (in an Aisin), and people just don’t have issues with it. The fluid lasts much longer than “traditional” ATF fluids. It’s also hydroscopic, which is why the transmission doesn’t have a
dipstick.
What a poor choice for lube! Lets look at the ignored brake systems that have the same problem with hydroscopic = fluid performance loss and RUST in the system. The NV5600 is a perfect example of lifetime lube means lifetime of lube over = transmission failure. If the other design defects like lack of lube to a bearing corrected by the aftermarket didn't burn it up first.
The HD use transmissions had better have a dipstick. Apparently the collective experience here doesn't have enough "Bad Luck"!
First No Dipstick
Disposable Car for me was a GM rental in 2002 or 2003. Coming off of work I noticed a puddle under the rental. Someone had found a parking curb and punctured the FWD trans pan. AT that time the work site is in the middle of NOWHERE with 30 miles of NO Analog Cell Service. I have NO WAY WHAT-SO-EVER to make an informed decision of how much fluid is left in the transmission vs. risk to get home. Something pickup owners take for granted is the parking brick that will scrape up a "low rider" sedan. Potholes and speed bumps have potential to hurt a sedan as well.
I made the rental company tow it and called it in from a POTS line at work. Much wasted time
of MINE over a lack of a dipstick.
Plenty of road debris on and off road that can and will pop a hole in a pan. Adding oil can save an expensive tow and a DIY repair keeps the pain down. You just haven't lived unless you have pounded a dent out of an oil pan that was rubbing the counterweights. And no: I don't offroad that much.
Tell me about the seals that NEVER EVER LEAK. Or yoke plugs on the driveshaft for that matter...
