01.5 power& milage vs 99
Very Sluggish Tranmission
transmission fluid
so i am to understand that whatever mods were done to the ecm programing from 99 to 01 results in lower milage????
I have to answer more from having followed this board closely for over a year, more than from personal experience. With that disclaimer, NO, I don't think there should be a big difference between 99 and 01. The big change was from the 12 valves to 24 valves at 98. 5, so unless you had some rare 12V with a 99 sticker, or you bought a 98 that was still on the lot in 99, you should be seeing approximately the same performance. And even if it was a 12v vs. 24v thing, your performance should be up, even if your mileage was down. Based on that plus what you have said, I think you are right to suspect that there is a problem with your truck. I would say, before you spend money BOMB'ing, get the stock truck right first.
Others have given you several good things to check first, so I'll start with a long shot: Watch your rpms closely, and see if you can verify that your torque converter is locking up when it should. Once locked and at cruising speed, I don't think you should get any engine speed variation unless pulling a fairly good hill. I had an old Suburban once; one wire came loose, the vehicle drove normally but with no lock-up, the mpg dropped about 1. 5 mpg. Found the problem by letting a good transmission man take it for a test drive; he could tell right away by the feel that something wasn't right, but to me it all felt OK. :eek:
You might also want to check http://dodgeram.org/tech/dsl/troubleshooting/24v_trouble.htm
A couple of things I noted - one is the fuel vent cap, which sometimes gets left on new trucks, and can cause poor power (there's also a link to pictures of the location); the second thing I noted is that "weak lift pump" is the only item that shows up under BOTH "low power" and "poor fuel economy".
Once you've tried all these "do it yourself" things, I have to say, you simply have to find a better dealer or a good Cummins shop. Good luck, I know it is a lot harder to find a minor gremlin than something that just makes the truck stop running altogether!
Sorry, me again, with more homework for you: :eek:
http://dodgeram.org/tech/tsb/0_01tsb_indx.htm Listing of all TSB's for your Ram
See especially
http://dodgeram.org/tech/tsb/2000/18-024-00.htm
... applies to vehicles with diesel + auto and date of manufacture between 12/15/99 and 11/15/00 (which will include some 2001. 5's)
Symptoms:
The customer may complain of low engine power and/or poor performance. This engine condition may occur while the automatic transmission is being operated in its overdrive gear. This condition may be further aggravated if the customer is using the vehicle for towing purposes.
HC thanks for the reply
naturaly my 99 truck is a 24v,tested the fuel pressure today... looks good(see other post)
im shure the lock up works,no rpm diference between the 2 trucks at same hw speed
ps truck ordered march 01 recieved may 01
My overhead computer doesnt tell me the truth! It constantly says 19. 2 - 19. 4mpg but checking against the trip odometer, I'm getting 17. 4 pretty constant. It didnt change when I installed the VA. I also dont have the ECM programmed for the larger tires. Any ideas? I always figured that it was a bit optimistic. Maybe they just recalibrated it for 2001??? Made it read true?
