'03 3500 Srw Gvwr - ????
Does the 03 CTD ISB use a lift pump?
Pilot Injection on New Common Rail??
Well the 3500 DRW is supposed to be available as 12,000 GVWR. What is the anticipated GVWR of the new SWR 3500. Also, will the '03 be heavier and cut into the payload capacity more?
Safe guess on the 3500 SRW would be at or near the 9900 of the F350 equivalent. A GVWR of 10,001 puts you in vehicle class 3 and is legally a medium duty truck. GVWR between 8501 and 10,000 is class 2 with medium duty emissions. GVWR 6001-8500 is class 2 with light-duty emissions.
Wow, THE KC Jackson from RTML and Dirt lists? Nice to see you posting. Us "old timers" in terms of the TDR site need to stick together.
-Paul R. Haller-:D :D
How in the name of Purple franklin did I miss a SRW 3500???
O. K I am listening at full attension! (Hmmmmmmmmmm "Gee uh ummm hey honey well ya know how we talked about the dually ... . Well I know theres alot of $ into it but theres this NEW rig coming out and ... ... )
For Sale:
Yeah watever
<hr>
Truck Bio:
Y2K+1 3500 4X4 Quad Cab 4:10:1 LSD
Somewhat Powerpacked By Bank's (4 inch exhaust,High ram intake,~Minus~wastgate mod to 38 psi,~Minus~ottomind TLC +guages,K&N) ,Blue Chip Premium FMC DTT~93%TC~&~VB~TC Smart controller, Mag-Hytec's Double Deep Trans pan,DD injectors+Van Aken+Autometer Guages. ,Piers Modified PDR HX turbo,Enterprise Engine PerformancePusher pump setup Front End Leveling Kit from Jakit with 255/85R16 BFG http://www.bfgoodrichtires.com/ M/T's Custom Rhino Liner (see Tool Man's truck feature)DeeZee Black Diamond Plate Bed Rails And Tool Box , WAAG Side tubes with kick~outs Mopar Performance accessories-Sill plates-hitch cover-cargo aux lamp'n'Power, Hadley air systems 150 psi comp and air storage. DynaMat Sound deadening applied to entire cab and doors, Check out Tool's Stuff#ad
N. E. T. D. P
Three worded story ... ..... "over 1350 posts - a new record!"
