rbattelle
No, NEVER EVER full current thru the ECU.It would melt the internals in a second...
Component should still be fused between supply and load to prevent agasinst catastrophic failure. Could be a fuse, relay, or even fusible link covering it.
I'm sorry, but in my opinion on '03-'04. 5 trucks there is no fuse or relay between the ECM and the lift pump. Nor is there a fuse between the lift pump and ground (which would be silly anyway). I'm no EE, so I fail to see why the LP current (which can't be more than 20A LRC) would fry the ECM. Are the traces really that small?
The attached photo is from the 2003 service manual, and shows circuit K62, which connects directly to cavity 45 on ECM connector C1. I have verified the accuracy of this schematic by visual inspection. Again, I have always assumed that there's an internal breaker in the ECM on that circuit.
Looking more closely at the schematic for 2005-up trucks, I see the LP connects via circuit A109 to the TIPM at cavity 18 of connector C10. It's not clear from the schematics (this TIPM system is spaghetti!) which fuse and/or relay is running the lift pump. In fact, I can't find any clear indication that any fuse or relay is in use on A109, but I believe brods. The wiring diagram just stinks. (In Dodge's defense, it is a very complex system and they did the best they could).
So in answer to my original question, yes the TIPM added a fuse and relay to the LP circuit.
Ryan
