mgoncalves said:Do they still use them? I thought they switched back to aluminum shortly after going to the plastic junk?
grant no I will not use the facroty inercooler. not to sure witch one I will use.GWBourne said:thats a bummer. are you going to have it replaced from the facroty or an upgraded one?
grant
black05 said:grant no I will not use the facroty inercooler. not to sure witch one I will use.
yes they are replaceing it with a metal one. still thinking of going biger after all go big or go home. :-lafGiachino said:I believe they will replace the original plastic one with a factory metal one under warranty..... not the same as an aftermarket one, but free.
lmills said:Dodge isn't the only one. Ford has been doing it for a while also. It took me 1/2 hr to loosen a couple bolts and replace mine. Heck, it probably takes me longer to change my oil.![]()
