At least your not crying about it. Althought you did attempt to hide the fact that you were running a electronic controller. Dodge (and not just Dodge, Chevrolet and Ford too have caught on to this popular trend on boosting power) has wised up and is on top of these issue, they do not play around any more. Once the determination is made that you have voided your warranty for one reason or another, they get the word out fast to all the dealers. No more dealer shopping to see if you can slide by, this now follows you and your truck by Vin Number, bottom line is they are tired of being burned by hot rodders that want power but expect them to fix things when something happens.
Also, not sure if you have noticed, but there is an alarming trend happening. The newer trucks are having far to many troubles. First it was the axles and running gear after they switched over from Dana. That issue is still a hot one, but what is worse is the engine problems that are springing up. Read through the post of the newer trucks and there is a rash of engine related failures. Many, many requiring a new engine assembly. I am seeing many piston failures and injector problems , and they all seem to start with rough idle,running conditions.
Getting back to the thread, I do not think it wise to be playing around with to many aftermarket toys, considering the problems Cummins is experiencing. Yes Cummins is a good engine builder , just not the great one they use to be. I believe most problems stem from the 5. 9L block having run it's coarse. After 30+ years of service and what with the last 5 years of the power wars between the big three(3), I think the 5. 9L has been push past it's window or margin of reliability. Years ago the engine was over built, it put out 160-180HP and would run all day for 300-500 thousand miles. Now it has been pushed to 350HP, and is not anywhere near as reliable. It has simple run it's coarse in time.
Why do you think they are coming out with the 6. 7L???? And why do you thin it is only rated at 300HP?????
Think about it????? This is the start of a new area, like the 5. 9L was 30+ years ago. The 6. 7L was built with todays HP and Torque ratings in mind. The block, crank, rods, pistons and everything else that make it work, were designed around the ideal of an engine 300 and up HP. The new 6. 7L will once again restore the "beef" to the Cummins engine. That same "Beef" that was eaten away over the years as people wanted more and more HP.
I have heard so many people say, "The new engine(6. 7L) isn't important, it is physically bigger and makes less HP". Well I say you are dead wrong. You are looking at the issue through tainted spectacles. The new engine will help restore the durability issues that have been lost, and play the foundation for the next generation of diesel power.
Yes the new engines will have to meet stricter emissions standards, but all engines, gas or diesel, have to meet ever changing EPA standards. If we want more diesels in our future, like the Euopean's have, then this is one step we have to make. I think diesels are on the verge of a major break-out in the USA, they are cleaner, quieter, and more powerful then ever. Almost every major auto maker is working on some type of diesel power plant to offer up to the US market. Today, where I live gas is over $3 a gallon, with all the action set to take place over seas, who knows what it will be next month, I would not be suprised to see $4 soon. VW has a TDI that get 50+ MPG, and looks good doing it. Honda is already selling it's civic in Europe with a diesel. Ford will come out with there new6. 4L twin turbo charged diesel in 2007 for the Super duty Pickups. It's a great time for diesels, just maybe not a great time to start bombing on them.
