10K lbs adjustable ball mount
Fifth wheel tire problem
Adding small crane to goosneck? (LONG)
Where can I find a 10K lbs adjustable height ball mount for my class IV hitch? Seems no manufacturer makes anything that will withstand more than 6,000 lbs :confused:
Thanks! Dan
We just started carring an aluminum alloy adj. ball mount where I work & I think it's rated at 1300# tongue wieght & 13,000# trlr. wieght. Kind of pricey I would guess. REALLY NICE LOOKING & REALLY NICE CRAFTSMANSHIP. I'm going to the shop today so I'll check on price & wieght cap. & brand name & let you know.
Rick
Try the "Balls of Steel" or "roto EZ" I have this hitch and I believe it is rated to 10,000 lbs. It adjusts 7 - 8 inches and also offers 3 different ball sizes all on one unit. It is stout, built from solid 2" stock with heavy gusseting - I think it weighs around 70 or so lbs. There is a # on the hitch - 800 995 9825. It is actually 2 dfferent parts, the adjustable hitch and the 3 sided ball mount. This thing is big, and mine is red - does a good job keeping tailgaters back too. I've been happy with it, but for most trailers it has to be dropped all the way down for my 4wd. It can also be flipped over and then used as a raised hitch for lower vehicles like my little motorhome.
Hope this helps,
Craig
Anderson's UltraHitch
Just got my Anderson's hitch today from www.HitchesOnline.com. Rick you were right, the craftsmanship is great :cool:
Can hardly wait to use it Oo.
Specs:
Light weight (18 lb. ) aluminum construction
Double ball features reversible 1-7/8" and 2" balls or 2" and 2-5/16"
10,000 lb. Trailer GVWR and 1,500 lb. Tongue weight.
12" total vertical adjustment. 6" adjustment with the rack up or down.
To all, thanks again for your help. Dan
