Dvolk, Excursions work nice with manual trans. There are a few thread out there with converted excursions. some of the wiring is different from a truck so when you do a full a swap and want it perfect you need to do some cutting and rewiring. I don't know exactly how / what the previous owner did to it , and I don't think it was done perfect. I had to redo alot of it and still have some issues. This truck was converted before I had bought it. It had NV4500 and dual disk pulling clutch. The Previous owner did not get the speedo to work. I thought it was bad diff sensor, swapped that and haven't had a chance to try it yet lol as its been sitting since 2009.
As I mentioned I am truing to get the truck on the Road ASAP to use it as a family vehicle and my new Plow Vehicle. We are trying to close on a house and it has 1100 foot up hill gravel driveway etc so a dependable plow vehicle and v plow will help ALOT. Its already dropped into the 20's a few evening and I hope to get the gold excursion on rd before snow flies. Our Other Excursion is still in body shop...... Friend helping a friend repaint turned into months in shop. Truck has been in since Feb...... Friend says he hopes to have it done by Halloween. I take that to mean Thanskgiving the way things have been going. So with 4 kids fitting in my dad's 2002 2500 Dodge Excab its tight fit for 6 people!!!!! The Other Excursion is a '05 Eddie Bauer. I rebuild the engine last year $14 k later all bullet proofed, full engine rebuild, regulated return, remote fuel and oil filters. A1000, welded deleted intake, BPD remote oil cooler etc etc. I have along build thread over at Powerstroke .org. Here's the link if your interested.
http://www.powerstroke.org/forum/6-...n/403050-05-excursion-cab-driveway-build.html
Photo Bucket is sooo slow!, that stated I have been working on it. 4 hrs to upload 20 pictures???
- Wife with our youngest - inspecting the progress
- The old twin turbo project is way to much of a pain to finish now. So Removed it. I cleaned up a old ford F800 rear drop manifold I have, and the turbo from my first gen plow truck. H1C with map width groove, and 12cm wastegated housing. Have to fab the oil drain. and drill tap for pyro etc. Cleans up the engine compartment.
- The truck had a school bus center fan pulley and would not fit a regular fan.I removed the dual electric fans, and swapped in a dodge fan pulley and a 1st gen clutch fan . like that better as less stuff to screw up. Just need to get a fan shroud to fit...
- I cleaned out the interior as it was a storage shed for the last several years argh. I had ordered a ACC ( Auto Custom Carpet) Black vinyl floor years ago. I ordered 2 yards more of the same material so I could make a removable floor section around my fabbed transmission hump. lol. The transmission hump seems to fit well when I built it a few years ago. but now I can't seem to get 3 holes to line up perfect.
- I am not going to redo it again as I'm very short on time. So I bolted it down, and sealed it up . I was going to buy a boat load of dynamat type sound insulation to and do the whole interior. But again lack of funds and need for vehicle on the road ASAP curtailed that idea. The ACC kit comes with the Jute floor insulation but not much. No Instructions and the vinyl is not molded or cut . So its all guess work and hand cutting. Laying it in the sun helps but when its chilly in the fall the vinyl is stiff. The Shifter boot I think is from a Dodge? I have two styles here a rounded square and a square style.. I mounted it up and used a Gripper Shifter I bought used. The Knob will be a push button style to activate the 4" remote pacbrake. I don't like the feel of the knob so far and may just make it a nice Cummins ball shifter from Genos, with a push pull switch mounted on shifter.
- I want a 60/40 folding center console front bench seat. Found a nice leather heated power one but its $700 .. so found a clean cloth non power one in the junk yard. debating swapping it in whole and putting seat covers on it, or just swapping in the center seat / console in with the leather buckets i have now. You can remove the inner armrests on the buckets to make it work but its not pretty but works.. an it fits my limited budget.
- The 10.5 Sterling rear in the truck had a leaking rear cover . I pulled it and found the ring gear was chipped. Its 4.10 ration. has 135k on it. Found a 77k 4.10 rear from a 2000 F250 gasser. It was REALLY Rusty but clean inside. Took a day and beat / burnt the rust off. Primed and painted it. The Gasser diff and some early diesel diffs had a regular yoke instead of a drive flange. Researched and found I can either unbolt and pull the yoke , then re set the pinion with new crush sleeve and set it up again or take the drive flange off my rear drive shaft and just put the u joint in the rears regular yoke. That is much easier!, supposedly it only makes the rear drive shaft compress 1/4 " the slip yoke should take that no problem. When I get $ I will get the Dana 60 SD front and this rear regeared . with lockers and either 3.31 or 3.55's. any thoughts?
- Have to swap in the rear and do the rear brakes. debating pulling the brakes from the truck off and saving $ or buying new .. new is easier but it needs full re brake, dorman backing plates, calipers, rotors, lines and hoses etc... have to see...
- Ordered '05 and up harley style head lights. I need to cut the header panel to fit them and updating the wiring pig tails etc...
Thanks,
Deo
