You will need the front gear case, injector lines and injectors (or custom lines), return lines, piston lift pump (orig 2nd Gen, not 1st Gen pLP). You are looking at probably more than the engine is (or will be after the conversion)worth to do the swap. The VE pumped engines are good to 500hp or so and still be streetable.
Daniel
